1 - 7 of 7 Posts
Caution! Girl working
Hello :)
Is it OK to prime furnace room walls in winter?
I'd be using Sherwin Williams exterior concrete primer to prime below-grade concrete walls in a room that's about 15 x 20 and has an oil-fired furnace, which will be running. I can put a fan in the doorway to help ventilate, but the window doesn't open (it's being replaced in the spring).
Mostly I'm worried about the fumes being flamable? I know you're not supposed to paint near 'open flames' but does a furnace count as an 'open flame'?
Thanks much!
Premium Member
Yes, a furnace counts as an open flame as do water heaters. Wait til spring since you will be replacing a window anyway and messing up the walls. Just do it all SAFELY in the Spring.
1 - 7 of 7 Posts
