I have a 2 ton Rheem central AC unit.
There are three lines that runs from the inside air handler unit to the outside. A 1" PVC condensate line, a 3/4" soft copper line and a 1/4" copper line.
What happened was I hired a contractor recently to do some demolition in my backyard, and the contractor needed a bobcat to help with the demo and hauling dirt back and forth. Long story short, in order to access my backyard he needed to remove the outside AC unit to make way. He said he would put it back once the job is done.
The outside AC unit was removed. The bobcat came and tore up the AC pad as well. So after the job was done he had to pour a new concrete pad, only he did it in the wrong place, off by about 2 feet. So the copper lines can no longer reach the connection on the side of the AC unit. I would prefer he pours the concrete pad at the right place because not only the copper lines the electric conduits are short too. But he opted to extend the copper lines instead. I found out when he was done, the two soft copper lines exiting the concrete wall are now "out of round". He must have tried to pull it and it kinked. He put some foam insulation on it but I pulled it off and I see the kink. I asked him about it and he said it shouldn't affect anything if they are not ruptured and leaking.
Is that OK? Will it cause problems down the road? Does it affect performance or cooling efficiency in any way?
