I bought the supplies I need. Torch, flux, solder, wire brush, sand paper and flint. Never done this before but I'm about to conquer a few projects. First one is simple, I just want to cut a piece of line that has been capped, and recap it further down.
I've read a few tutorials online and it seems fairly straightforward. Clean the fittings, use wirebrush to rough them up, apply flux, dry fit, heat the fitting, remove flame, apply solder, if it does not melt right away it needs to be heated more. Once it does melt, just follow the outline of the fitting and solder is sucked in then let it dry and wipe down excess and turn on water.
Now is this one of those things it works, or it does not, or could it hold for a while, then randomly burst when I'm not home? That's really my main fear when working with high pressure applications.
What is the best way to test that I did a good job and it will last? I'm thinking I could simply cause lot of water hammer by turning a faucet on/off very fast and if it holds, then I'm good right?
