hi! i'm in a 1 1/2 storey old post-war house, which means i have an attic space, and then two crawl spaces on either side of the second floor that run the length of the house.
the attic has gable vents and two roof vents and it seems like air is able to get in and out of it.
the crawl spaces are a different story. there is a very thin little perforated soffit that would allow a bit of air to get in, if it weren't for the fact that there is blocking in between the rafters along the top plate. there is also batt insulation stuffed between the rafters and the roof stays pretty warm during the winter, resulting in significant ice damming (this past winter was my first in the house). in the summer it feels like a sauna in the crawl space.
my plan is to remove the batt insulation between the rafters and put it along the knee-walls and in the floor of the crawl space to prevent heat from the house from transferring to the crawl space. then i was thinking about drilling a hole in the center of each piece of blocking to allow outside air to come into the crawl space. i figure in order to facilitate air movement, i would then need to either install a gable vent or another roof vent.
can anyone tell me what's the easiest vent to put in?
