1 - 12 of 12 Posts
6 months ago, I used some z flashing for the joint between T-111 siding and ChoiceDek composite decking trim, which I used to trim the bottom of a shed (gets the T-111 12" off the ground).
I notice that the flashing is already showing areas of white powder & pitting. The flashing is properly installed so as to not retain water.
Is this typical of all z flashing, or is there a better quality available? I bought the z flashing at lowes. It's pretty thin.
Thanks!
There are different grades and thicknesses from different manufacturers.The problem with yours seems to be the finish.I always used anodized from a quality manufacturer and purchased at a lumber yard not a BB store.
Aluminum or even steel flashing should never have been in direct contact with PT wood.
The copper it's treated with will corrode it in no time.
Reactions: Bob...
Joe is correct.I was not thinking about the PT aspect when answering your question.
I live in farm country and we build lots of pole barns that have z along the pt boards at the ground level .The Z we use on them holds up for many years without issue.They are painted/coated with some sort of a ceramic paint that does not react to the PT wood .I think even HD sells some pole barn metal these days so you may try that.They have the Z and some other trim pieces in limited colors and quantities.
Discussion Starter · #11 ·
Thanks for your suggestion, Chuck.
Also, just wanted to post back. Since I haven't been able to find the coated stock around here. The vinyl suggested by WoW is viable, but I've also been told that copper flashing would work. I don't need that much, so expense shouldn't be an issue. Also, I have easy access to sheet metal shops via my business.
Any reason not to use copper?
Discussion Starter · #12 ·
Now for the final question: Since I have to give the measurements I want the flashing cut & bent to, What are the recommended tolerances? I really don't want to use the same measurements as the Lowes z flashing, as I thought it was a bit undersized.
From the diagram below, what dimensions should the flashing be cut to?
Also, I believe they cut from a 10' sheet. The long side of the shed is 10' 1 1/2", but I plan on using MiraTec trim at the corners. Can I assume that a 3/4" shortfall at each corner won't be an issue under the trim?
Apologies if the questions seem a bit anal, but I'd rather not do this again. Thanks!
Text Line Font Slope Diagram
1 - 12 of 12 Posts
