1 - 11 of 11 Posts
Main water line into house is a 3/4" meter and copper pipe. It is reduced to a 1/2" just after it enters the crawlspace and before making its way to the water heater. Should I tap for an irrigation line with a 3/4" pipe before the reduction or tap with a 1/2" pipe after. I am worried that if I tap before then it will screw up the flow to the house.
Tap before the reduction,it won't bother the flow to the house.
Did anyone notice he only has 1/2 main runs?
What do you thinks going to happen to the flow and pressure in the house when those sprinklers are running?
Go back and read it again. Someone messed up and used 1/2 to the heater and for the main runs.
He only has a 3/4 supply to the house.
you would have to have way more zone then you would want to spend money on if you try to use the 1/2" side of the line, 3/4 like has been said is still going to be a pain, what is your water pressure? in the house and off the 3/4 side?
1 - 11 of 11 Posts
