Wife and I were considering the addition of an attached screen porch to the back of our house. It'd be built on a slab, existentially just above ground level. The hiccup is that because of how the house is laid out, it makes the most sense to build it off our master bedroom and not a living space as you'd normally do. The master bedroom has two windows, both of which would be enclosed by the construction of the porch.
Found what appears to be a significant hiccup with building a porch there. From the 2012 IRC, Appendix H, which lays out requirements for "patio covers". Since we'd be enclosing the only emergency egress points of our bedroom (the to windows) within the porch, I think it'd violate this section. Sounds like it could be a pergola without a problem, but the second you enclose it, even if it's only screened . . . it's a no go.
Below is a section from Appendix H of the 2012 IRC, which covers "patio enclosures". Our local building authority defaults to the IRC guidelines.
Does enclosing the windows within the porch structure violate this section? The last two sentences seem to conflict a bit in this instance. The emergency egress points would be enclosed, but would have an exit door. It sort of suggests that it'd be fine if we replaced the two windows with a pair of french doors?
SECTION AH105
LIGHT AND VENTILATION/EMERGENCY EGRESS
AH105.1 General.
Exterior openings required for light and ventilation shall be permitted to open into a patio structure conforming to Section AH101, provided that the patio structure shall be unenclosed if such openings are serving as emergency egress or rescue openings from sleeping rooms. Where such exterior openings serve as an exit from the dwelling unit, the patio structure, unless unenclosed, shall be provided with exits conforming to the provisions of Section R310 of this code.
SECTION AH105
AH105.1 General.
