Hi,
Hope you can help me to look at the right direction...
Have Goodman furnace for 5 years, it's GMVM96, was running no problem all the time.
Recently it started failing to start up heat. When it happens I find the furnace with solid "H" in the diagnostic window and no flames. Usually restart would solve the problem but it started getting worse: Lately when I restart the furnace with the switch, it attempts to start, the fan is on, ignitor starts, flames are on and visible, and then fan is slowing down and eventually the flames are shutting down. Furnace makes 3 attempts and then shuts down with the E0 code. I used Fault Recall button to clear up the history and after that the furnace started as normal. This happened more than twice now so there must be definitely a problem.
What I am not getting is that if that would be a physical problem with something, the furnace would not start at all, but it is intermittent so I don't know where to start. I checked and cleaned the ignitor sensor, changed the filter and thermostat batteries, checked pipes. Please help.
