I have an unfinished basement that occasionally leaks water. I’ve trenched my gutters and worked on the grade around the house. Both helped tremendously but I still get water with heavy rains. The basement is a walkout and has a garage door. The front wall is against soil and the side walls the soil slopes away.
Eventually I want to finish the basement. Water only comes in along the walls where soil is above the footing. I’ve also seen it bubble up through a concrete crack.
I’ve had two quotes for installing an interior French drain and sump pump. Both came in around $70 per linear foot. So pretty expensive!
I also know that my house has radon. If I keep my basement windows open then long term average levels stay under 2.5. I’ve seen daily rates as high as 10.
One of the products was a water guard system and the other was corrugated PVC pipe. Both products had a lip against the concrete block wall to allow any hydrostatic water to drain.
A couple of questions:
1) do I need a full perimeter interior French drain? Or just against the walls with soil and leakage?
2) does the lip against the concrete wall allow more radon in? If I later install radon mitigation will I have to seal that lip?
3) Can I discharge the sump pump into one of the trenched gutters or is that too much water? 2000 sqft roof, 4 total gutters. Front gutter trenches to rear gutter, connected together and then trenched 50Ft away.
