1 - 7 of 7 Posts
I have a few interior doors in my home that once open fully(pushed all of the way open against the door stop) that will not stay open. The doors continually and slowly close. Are there tips that I can adjust the door(without affecting how it closes) to help them stay open?
· A "Handy Husband"
Remove a hinge pin, place on a concrete surface and whack with a hammer. This will deform the pin enough to heep the door open. The root cause is the door is not plumb. Caused by door not hung properly or the house has moved (sagged).
Reactions: GrayHair
· JUSTA MEMBER
Thank you.
As pointed out, you can try to tweak a hinge to compensate for any sagging.
Or I have had better results by figuring out where the thing has been messed up, and getting some small flat washers, and installing them underneath the hinge plate, just enough to cause either the top or the bottom of the door to tilt the right way to re plumb it to correct.
Put these flat washers over the hinge screws in either the top or the bottom hinge, whichever will cause the door to become plumb. Loosen all the hinges on the jamb, but just remove the screws on the hinge that needs tweaked, washers then reinstall the screws, recheck for plumb. Add or get thinner washers to get it exactly plumb.
ED
· A "Handy Husband"
Thank you.
ED
That will work if the door is out of plumb parallel to the jamb. Not if perpendicular to the jamb.
· Registered User
Reactions: rjniles
1 - 7 of 7 Posts
