Coax has a metal foil and wire braid under the outside insulation jacket. This is a "shield" which keeps outside electrical "noise" from getting to the inside wire. So as said above, it will be fine.
FYI - That outside shield is "grounded" at the equipment connection. That keeps it at 0 volts. (Other nearby electrical signals can't "induce" any voltage or signal in the shield or in turn the inside wire.)
And with that said, some "cheap" coax wire (typically white 6 foot lengths sold in retail stores) can have shields which only cover 50% of the inside wire, so some electrical "noise" can leak in. RG/6 coax is pretty good. And "Quad Shielded" RG6 is even better.
The "compression connectors" the cable TV companies use are better. Like the following, then after that is the tool used to install those connectors...
Coax cutting tool...
Quad shield coax...
