I want to replace my existing 15 year old smoke detectors. I have 4 detector that are 120 volt with 9V battery backup; they are not interconnected. The existing smokes are wired to 3 different circuits: 2 on a 20 amp circuit that feeds lights & receptacles in the dining room, one each on 15 amp bedroom lighting circuits.
I want to interconnect the new smokes. Here is a reference to the FireX smokes I want to use.
http://www.sentrydetectors.com/firex/manual/4618.pdf
I am aware that usually interconnected smokes use 3 wire cable and use the red wire to make the interconnection. I would prefer not to have to rewire the four locations.
The manual listed above indicates the interconnection can be made using 18 gauge wiring so I think the interconnection signalling is low voltage. I would like to run a single strand of #14 THWN between the existing boxes to make the interconnection. The FireX manual cautions that if different circuits are used to power the smokes, the neutrals originate from the same phase. This will require I rearrange one of the circuits at the breaker panel but is a minor issue.
My question is: Is my plan to run a single THWN wire (no conduit) between the smokes a code compliant method?
