I have a few questions regarding insulation:
#1) I plan to put 1" XPS board insulation directly against a cinder block foundation/wall before studding out a finished basement. Is there any reason to glue/fasten it to the cinder block if it stays up just fine on its own?(as I said walls will be going up right after)
#2) In that same finished basement, I was planning to put Rockwool's safe and sound in the ceiling, however, it is cheaper to actually buy 2x6 R23 Rockwool. Is it OK to insulate the heated basement ceiling that is connect to the heated living area upstairs? Any downsides?
#3) The garage ceiling will also be insulated with Rockwool. Above the unheated garage are bedrooms. Should any type of barrier be used here, or will it just trap moisture?
#4) Our attic has full sheets of plywood down the middle. Pictures: ..and right now there is just 2x4 fiberglass insulation which is VERY under insulated for PA weather. I was think of switching this over to rockwool, but what is the best way to do it with the massive plywood there.
Thanks!
Thanks!
