I think I have poor insulation on one side of my house. Its an addition that was added roughly 20-30 years after the house was built. The bathroom on the addition side alone, has reached a low temperature of 41 degrees. The floor is tile as well as the jacuzzi tub is tiled. There is decent insulation in the attic on that side of the house. Much better than the original part of the house. Has R30 in the crawlspace but still very cold. I'm thinking the exterior walls in the master bedroom and bathroom has either very poor insulation or none. What would be a best route to go cutting holes between studs and use blown in insulation or tear the sheetrock down and reinsulate with fiberglass insulation.
Also what would be a good way to check if its poor insulation?
