Hello all,
I moved into a home that has some insulation issues throughout the house, including HVAC issues that I'm working on nailing down. I managed to borrow a thermal imaging camera from work yesterday and took a lot of photos and measurements of my home and the temperature swings. turns out the corners of the bedrooms are pretty bad... anyways, what I was actually curious about was the inside wall temperature and what it should ACTUALLY be vs. what I was measuring.
The ceilings seemed really bad to me and I think I need to get the attic re-insulated or get rid of the feathered insulation in there and get it redone.
The walls did pose an issue as well, but I suspect after this investigation that the ceiling/attic is the culprit. Can anybody tell me what the standard temperature differential should be vs the outside temps?
I can post some photos tonight if need be, it may help things along.
