Hi Folks and Merry Christmas,
I live in a northern suburb of Detroit Michigan. I have a 40 x 40 metal pole barn with a cement floor. I have attached a few photos. From what I can tell based on the township records it was built in 1969. I need to insulate it so I can work outside in the winter. I do NOT want to use any kind of batt insulation due to bugs and rodents. I do plan on finishing it out with OSB.
Would you guys and gals suggest using foam board between the wall grits?
Has anyone used this Prodex Total 48 inch insulation? It has a Reflective aluminum foil on each side of 5mm (13/64) closed-cell polyethylene foam center.
Any help or experience would be greatly appreciated!!
