I have a shop that is metal and I'd like to insulate it. Are there any specal considerations or specific insulation that I should be using different from that stuff you can get at the local Home Depot?:confused:
Commercial Roofing
Hve you considered spray foam?
urethane insulation
I am also building a new shop. I am going to have the walls and ceiling sprayed with 4" of earthfoam urethane insulation. I am using a one pound foam which is a closed cell foam. It is also bio based and water blown instead of petroleum based. Check out www.earthfoam.com
Goodluck
