1 - 12 of 12 Posts
We are remodeling the master bath which happens to be above the garage. Currently there is R-22 insulation between the two. I want to add some more to that, but am unsure of the easiest route to get it there. Should I pull up the subfloor, add batting and then new subfloor? OR should I make holes in garage ceiling and blow in some more insulation? Or make holes in subfloor to blow in more? How much more insulation can I add? The joists are engineered I beams that are 12 inches high and 16 inches apart.
thanks in advance
Mindy in Richardson, TX
I'd pull the ceiling down and spray a closed cell foam in there.
Assuming that the R22 insulation is in batt form and that there is a vapor barrier under the subfloor, I would suggest that you would blow cellulose insulation into the cavity that is between the insulation and the vapor barrier.
The cellulose can be blown into the cavities by drilling 1" holes through the subfloor.
After the joist cavities are filled, close the drilled holes using expanding foam insulation.
The only way to go! We used this solution a couple of years ago in exactly the same situation. The change in temperature of the bathroom is huge! You should at least check the price, it's probably not as bad as you're thinking.
Yes, the current insulation is in batt form with the attached vapor barrier to the underside of the upstairs floor. So blowing from the top would put insulation, vapor barrier, insulation.
Mindy
Discussion Starter · #8 ·
Do you know how many inches of foam you used? Just curious.
Mindy
Mindy
The cellulose fills the void between the existing insulation and the vapor barrier that is immediately under the sub floor.
Mindy
We put 6 inches of closed cell foam (about R-40). The big advantage is not only does it provide insulation but are also completely prevents air infiltration.
Registered User
1 - 12 of 12 Posts
