Look for cans that are IC rated. IC stands for "insulation contact". If the cans will be installed in an attic space, which I assume they will be due to blown in insulation, you will need air-tite cans. The designation for that is AT.
^^That.Look for cans that are IC rated. IC stands for "insulation contact". If the cans will be installed in an attic space, which I assume they will be due to blown in insulation, you will need air-tite cans. The designation for that is AT.
Are you sure you can even put the LEDs you bought into the unit?The LED connection is non-screw base to preserve the high efficacy rating of the luminaire
