Going to take on the easy task of faced insulating the cavity area above my garage. I have some R30 insulation that is about 16 inches wide and need to install in 16 inch on center joists. With that being said, measuring most of the spaces between joists is anywhere from 14.5-15 inches or so.
Is it worth it to cut an inch off from the sides of the insulation before installing or is the compaction minimal to stuff between joists where it won't hurt the R value too much?
Total will be about 15 runs around 124 inches long with 48 inch length batts.
Thanks in advance!
Thanks in advance!
