1- attach rigid foam boards to the concrete walls from floor to ceiling and caulk along floor and tape all seams. Build 2x4 walls in front of this. •• air seal the foam, fill the studs w/ Roxul, and air seal the sheet rock. Do the whole basement, too, or the cold side will be robbing from the warm, defeating a lot of your gains, unless separated by an insulated wall.
