I have a cape cod style home in Sacramento california (read: hot). I've insulated the kneewalls with rigid foam board and am moving upwards toward the attic. How do I insulate the sloped ceiling between the kneewall and the attic floor? Its basically just a cavity between the underside of the roof deck and the drywall of the room. There's some compressed batt insulation in there now......but inside the room that sloped part of the ceiling gets 90+ degrees so I don't think that insulation is doing much. The rafters are only 2x4, so theres not a lot of space. I have limited access from below and above . I was thinking of sliding a piece of rigid foam in there and then filling the cavity with cellulose. I would leave a direct path for the soffit vents to the ridge vent. How important is ventilation in my climate? Any advice?
