I'm exploring options for insulating the rim joists in my finished basement. There is currently bat insulation in some of the rim joists but its needing to be replaced. I've got about 100 sq ft to insulate (1440 linear inches * 10 inch rim joist width). Unfortunately, a majority of the rim joists are covered by a drop ceiling. I can move the tiles to get access but it's still going to be a pain to work around the drop ceiling. I'm considering a few options but have never done this type of project before so was hoping to get some advice before making a decision.
Option 1) Hire a pro and have them install spray foam insulation. I'm concerned that having to work around the drop ceiling will make the job quite a bit more expensive.
Option 2) Buy a combination of spray foam and rigid foam insulation and do the job myself. I'd cut the rigid foam insulation to size and then use something like great stuff pro to add insulation between the rigid foam and the joists to make it air tight. Leaning towards this option at the moment.
Option 3) Buy a DIY closed cell spray foam kit and apply it myself. I'm probably not going to do this but listing as an option. From what I can tell it's pretty easy for DIY spray foam kits to turn into a nightmare and given the price of each kit probably not worth the risk.
Of the 3 options I'm currently leaning towards 2 but wanted to get some advice from people that are more experienced. Does option 2 seem realistic and will it insulate/reduce draftiness as well as just applying spray foam? Any other options I should consider?
