Hi guys!
Here's some pictures of the area in question: :glasses:
Basement information:
So I’ve decided that I want to insulate this area to make my basement warmer:
I’m thinking…
Questions:
Thank you for your time! :vs_karate:
-I live in a 1976 made home, located in Calgary (Canada), winter here gets as cold as -30C but the climate is rather dry year round. Very low humidity.
Poured concrete foundation basement that’s had drywall in it since we moved in.
-15 years ago, we had installers put carpet in the basement.
This basement has been used as an extra TV/game room and partial storage room ever since.
-However, there is one area in the basement where there is no drywall. This is a small 5ft wide x 2ft deep section located underneath where the main floor fireplace is, just above.
Information pertaining to the bare concrete spot in question:Poured concrete foundation basement that’s had drywall in it since we moved in.
-Historically, we’ve always just stored boxes in this small space. There have been no water problems, and no signs of water damage on any of the boxes that have been here for the past decade.
-HOWEVER, this year, after I removed the Christmas decoration boxes from this area, I realized how COLD the air was in that spot.
-Without the boxes, it feels like it really just sucks the heat out of the entire basements air.
-The carpet is installed in this small area too.
-This has got to be hurting my heating bill.
I’m thinking…
-Install 2.5” thick (2'x8'), rigid blue foam board – Adhere it to the bare concrete walls with the appropriate caulking gun glue.
-Apply spray foam in lines along the bottom and top of the rigid foam boards, AND down the 2 wall corners, to make them seal “air tight”.
Questions:
1 - Does my plan make sense?
2 - Is it okay to install this foam board overtop of the carpet?
The carpet is stuck to the floor, and I am worried that if I rip it up there, the rest of the carpet may lose its "stretch".
3 - Should I insulate the concrete ceiling here? Remember, it’s under the fireplace. Should I leave it bare? It's not exactly an outside wall.
4 - All this area is used for is boxes... Should I bother putting anything over the foam board? Installing a 2x4 stud wall feels like it would eat a lot of space.
5 - Anything else I missed?
