I am curious about the right/wrong ways to go about this for a future finished basement.
I have metal duct work that runs in the joist bays. I occaisionally notice sweating on these. Lately humidity has been up and I have been trying to reduce the indoor humidity. I recently changed my thermostat with a unit that will run my a/c to dehumidify the house if it gets to a certain point. I think I currently have it set at 55% RH, but am thinking of reducing to 50%.
In any case most of the seams in the ductwork aren't taped or sealed, so I've been trying to go through and seal the seams. Is the metal tape ok, or should I be using mastic?
I am trying to get ready to hang sheetrock and finish the basement off, but I am worried about condensation driping onto my finished ceiling. I am also using fiberglass batting as a sound barrier in the joist bays, so that I don't get sounds from the 1st floor to the basement and vise versa. I recently purchased some duct wrap that is fiberglass with a metalic foil outside cover. Is this stuff ok or should I use something else?
I am also curious if I can just use regular fiberglass batting to insulate these ducts instead of the special made duct wrap? Again, the entire joist bay would be filled with the batting, so it would surround the duct. If that is not preferred, does it hurt to use the batting around the duct wrap, so that I gain my "noise barrier"?
Thanks for any input...
