Looking for advice on insulating the roof of on unattached garage. Garage is 20'X24' with 4/12 asphalt roof; has peak vent and vents at the eaves. I know I need to maintain a minimum of an 1" air gap between the insulation and roof sheathing.
So one option I'm looking at is installing R15 batts which would give me 2" of air flow.
I would like to increase the R value if I could so I was also thinking about installing foam baffles the entire length of the rafter run (from eave vent to peak vent) and installing R19 batts. This would still maintain air flow but the batts would be slightly compressed to sit flush with the rafters. Has anyone ever done this; or see any issues I would run into going this route?
The R19 batts are available in my local area and the R15 batts are not. It's about a 4 hour drive one-way to a big box store that carries R15 batts 23" wide and the price is only $5 a bag less then the local cost of R19 batts 23".
I'm still undecided if I will sheet over the rafters once I install insulation might just run 1" X 2" across the rafters ever 3-4' to help get the insulation from sagging.
