First, let me own my novice DIY status and say I probably screwed up. I bought a new house last year in the Indy area (5b) and immediately went to work finishing the basement. The builder attached batts of insulation to the top half of the poured concrete walls to just below grade. I framed the walls just off those batts, so several inches from the foundation. Didn't consider any other insulation as I assumed like a novice that I'd just insulate the stud cavities after everything was done. It's only recently I've become aware that the preferred option is rigid foam attached to the concrete walls from top to bottom for moisture control. I've now got a 2000 sf basement fully framed with electrical run and I'm wondering what my best and most cost-effective course of action is for insulation. Would appreciate any advice! If it makes a difference, I learned today that the builder used a waterproofing membrane (Hydra-Guard?) on the exterior of the foundation. Also, here's a link to a couple pictures if that helps: https://photos.app.goo.gl/1Kq5uGx6XoicXFBJ9
