My house is from 1986. The fiberglass was insulated with loose fill when it was built, however it was only 5 inches or so. I believe I need to get around 20 inches or so to acheive at least a R60 in the attic. It's a 1000 sqft attic space. I've already put in baffle vents and sealed them.
Issue I have is the attic entry is just a regular hatch (piece of drywall covering a hole). If I bring insulation that high, each time I try to go into the attic I will have insulation falling out. What are some ways to build up a wall. A simple way I was thinking was to put tall insulation batts around the attic entrance, they would act as a wall to prevent this.
