Greetings,
I am in the process of renovating an existing screened porch that was built long before I owned the house. The roof is built with 2x6 rafters connected to a header with regular asphalt shingles that match the houses roof. Previously, the ceiling was covered with thin plywood and the soffit was never vented (covered with exterior plywood). The porch was never excessively hot in the summers and i didn't see any moisture problems when i removed some of the old ceiling plywood. We live in NJ.
We are not 100% sure, but our plan is to install storm windows with full size screens, so we can close it up and extend the use of the porch by a month or so. We do not plan to ever install windows or hvac and want it to remain a 'porch'.
So, before i begin to button up the ceiling and knee-wall, should i go ahead and insulate? Will it help enough when the temp. start to drop, to be worth it?
The ceiling will be surfaced with 1x6 T&G bead board.
I've read that insulating a roof of like this, will only lead to problems down the road, i guess due to lack of air movement? If insulating makes sens, would installing ridge vents between each rafter, along with vented soffits, help to move the hot air off the roof?
Thanks for your suggestions.
