The space I'm trying to insulate is about 90 sq ft on the ceiling. I have a 70+ year old former garage with 2x4 framing. About half of the room is going to have a vaulted/cathedral/whatever ceiling. The other half has rafter ties, trusses and all that. It's the 'attic' portion I guess. I'm playing the hand I've been dealt. It's a tough structure to deal with and the previous owners made some very ill advised structural modifications. I'm trying to insulate three rafter bays, 24 on center each. Room is 11X15. I just got a new roof, and there are no vents. Messing with that might void the warranty. Vents down low are also problematic. I need a solution for insulating the vaulted portion of the ceiling.
I furred the rafters with 2x2s to give it a little more room and I'm not sure where to go next.
I thought about drilling several one inch holes in the rafters right next to the decking so I could vent to the 'attic' portion of the room, and then putting in 2x4 batts or foam board with spacers so I could leave a gap between the insulation and the roof decking.
I understand that the ideal solution for a 'hot roof' is closed cell spray foam. Called a contractor today and told them I just need 90 sq ft and they said it's $3500 to come to the job site. Everything on the web says don't try to DIY it, plus the kits start at around $300, and those kits don't include the suit and the respirator.
So here we are. I don't feel like I need that much of the spray foam and I wonder if umpteen spray cans of Great Stuff or something would do the job without the ridiculous cost...Or is there another way? If I use batts, installing baffles won't do me any good because there's nowhere to funnel the air.
This is not going to be code and I'm on a budget. Whatever I do is not going to have a super high R value. I just want to add some insulation without setting the stage for catastrophic mold damage and all that nasty stuff.
Any ideas?
Any ideas?
