Hello all, had a question regarding the use of insulated Ring terminals. When wiring an electrical outlet, I found that the push in connectors on the back don't do a great job holding the wire in. The other option I have read about is making the wire into a J and tie that to the side screw.
Assuming that the ring terminal is rated for the correct wire and amps, could one be used in place of the J wire on the side screw? Is that a no no for any reason?
For my house and I have it working currently using the back push in connectors that I have ungodly tightened with a screw driver. Was wondering this this could have been an option.
