What is MHF wire?
Mobile Home FeederWhat is MHF wire?
According to code, 4 wires to out building AND a grounding rod.first no ground at garage.U will have to run 4 wires ground included. 90 amp????
I haven't priced it yet, but I am also assuming the cost will be similar. The advantage of separate wires makes it an easier pull, but the conduit is 2" and a straight run with just 2 bends so hopefully it shouldn't be too difficult. Appreciate the advice, something to think about.Personally I would run conduit whenever I could.
Have you priced out the cable vs individual wires in conduit?
Conduit always provides a neater installation.
You can bury the metal in the rocky soil and transition to PVC since you will be running a ground wire anyway.
I would think at the very worst the cost may be the same.
Have you already bought the conduit?but the conduit is 2" and a straight run .
I already bought and installed the conduit underground.Have you already bought the conduit?
I believe you can use 1 !/4" for 3 2's and a ground.
Code reference please,According to code, 4 wires to out building AND a grounding rod.
The panel will need a grounding system . The panel does not meet the exception for a single circuit.first no ground at garage.U will have to run 4 wires ground included. 90 amp????
nec 250.32 (a)code reference please,
