I'm buying a house with a pretty old panel + meter socket combo. It has no main breaker, and it has only 4 breakers. It's also incorrectly wired: one of the circuits is directly connected to the hot bus, and another breaker has two circuits on it. I was recommended to replace the panel. I'm planning on adding to the house in the future, so replacing the panel really seems like a good idea.
I want to give a try to do the replacement myself, and I'm trying to gauge the complexity of the project. I think I can manage the wiring, but the mechanical part is a little questionable. My biggest problem is how to mount the new panel on the wall. I never mounted anything more than a coat hanger.
This is in California, the supplier is PG&E. I was planning on using this panel: http://www.homedepot.com/h_d1/N-5yc...splay?langId=-1&storeId=10051&catalogId=10053. Does anybody have some info on how should I mount the panel, what is code and what is not? Simple things like how to cut the wall, how do i support the weight, etc. The wall is currently covered with stucco. Maybe I should post this in a drywall forum? Sorry if I'm off topic.
Thanks,
Balint
Thanks,
Balint
