Hello,
I need some guidance on the installation of a SwitchLinc Dimmer product #2476D. If needed, product information and owners manual can be viewed at:
http://www.smarthome.com/2476D/SwitchLinc-Dimmer-INSTEON-Remote-Control-Dimmer-White/p.aspx
The problem I have is I don't know where to connect the switch white to?
The switch box is new wiring, I ran 14-2 wire down the wall from a recessed light in the ceiling. The light is also new and has 14-2 running from the power source (to the light); so the switch is considered to be at the end of the line. The light is a low voltage juno can, magnetic, and the SwitchLinc Dimmer is supposed to work with this light.
The current wiring is in the light is as follows:
source black to switch white (connection made in the light's box)
source white to light white (connection made in the light's box)
switch black to light black (connection made in the light's box)
This leaves me with the following in the switch box:
a white (hot) in the switch box
a black (load) in the switch box
Now I'm left with connecting the SwitchLinc Dimmer's white, black, and red wire's to the above.
in a standard switch (non-dimmable) when i connect the switch black to the switch left terminal and the switch white to the switch right terminal, everything works fine.
But when wiring the SwitchLinc Dimmer, I don't know where to wire the switch white wire to since the switch has 3 wires (red, black, white) and the wires in the box only have two (black, white). If needed, I can run 14-3 down the wall to the switch, but my next question would be how to wire the light to the source.
I thought I could get this done with 14-2 to the switch, but it is looking like I need to redo it with 14-3....
Thanks for your help!
