1 - 12 of 12 Posts
I’m trying to install a Honeywell PLS750C timer switch (CFL & 3-Way compatible) in place of my current Patio 3-Way light switch. The other 3-way switch is in the Bedroom. There are 3 external light fixtures controlled by the 3-way switches and they have CFL bulbs. I’m having issues getting the timer switch to work at the patio switch location.
Existing Patio 3-Way Switch wiring:
Existing Bedroom 3-Way Switch wiring:
Following is a link to the Honeywell Timer Switch User/Install Guide:
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2504EFS.pdf
I think the 3-way wiring for my patio lights is something like what is shown in the following link. I suspect the white/neutral wires on my 3-way switches are really supposed to be white with black tape, but I’m not 100% certain about that:
http://www.homeimprovementweb.com/information/how-to/three-way-switch-option8.htm
The behavior of the lights, switches and wiring voltage are as follows for the 4 possible switch scenarios:
Any suggestions, or view on whether or not I can install the timer switch at the patio location? I read somewhere that a timer switch may require a constant hot and constant neutral, if so I guess that rules out the patio switch location? And if true, would that also rule out the Bedroom location as a possible place to install the timer switch?
Your timer switch requires a neutral.
What other wires do you have in the boxes in the bedroom or patio?
The white you see is likely a traveler.
There is a timer switch, the Intermatic ST01, that does not need a neutral if it comes to that.
Edit: please tighten the screws on those switches. They look really close to the bare ground.
Can't really see if there are any other wires in the box of your first picture.
Is it just the 3 conductor cable in both your switch boxes?
If so, like AandPDan said, your switch requires a neutral and you won't have one in either box.
Discussion Starter #4
Thanks AandPDan & tfo411 for the replies. The Patio switch is part of a 3 gang box (other lights - 4 yard & 2 grill area fixtures), so there are some other white wires in the 3 gang box that may be neutral, but a challenge at the Patio switch would seem to be a constant hot wire I need for the timer switch. The Bedroom switch only has the one wire (3 conductor cable) shown. So, I saw the Intermatic ST01 but was leaning toward Honeywell since I have them elsewhere in the house. I may revisit the ST01 though. Also, thanks AandPdan for noting the extended screws, I had not noticed just how close it was to the bare ground!
Discussion Starter #6 (Edited)
Ok, here's a couple pictures of the gang. The right switch is the 3 way I want to put the timer on and the left is a single pole for 4 lights. Both the right and left switches are on the same circuit breaker. The middle is a single pole for 2 lights, on another circuit breaker.
Following is a close up. I identified a White pigtail that has no voltage when all lights are on. The labeled Hot is the power for the left switch which has constant voltage, and as previously mentioned is on the same circuit breaker as the 3 way switch.
Discussion Starter #8
Thank you AandPDan for coaxing me along! I'll connect the new 3-way timer white to the neutral pigtail and it's black to the hot black pigtail that are on the same circuit - sound correct? Do you have a suggestion/idea on how I should connect the old 3-way switch wires (red, black, white) to the remaining two wires on the new 3-way timer (ie blue & yellow)?
Follow the directions is my best advice. I think it would be easier to go with the "new" 3 way switch install, change out the other three way to a single pole switch.
Just cap off the unused wire at both ends.
Good luck.
Discussion Starter #10
Thank you so much AandPDan!! I took your suggestion, put a single pole switch in the bedroom to mirror the 'new install' per the instruction. I capped off the red wire at both switches, connected the new 3-way timer switch wires per the instructions and it works perfect! Again, thank you!!
4way
Hi - I have 2 3way switches and a 4way switch operating the same lights. After wiring the 2 3 way switches acc to the instructions, both worked. But the 4 way switch no longer works. Do I need to put a jumper wire on the 4 way?
1 - 12 of 12 Posts
