Hi all,
I am replacing old casement windows from the 1950's. I measured the inside and the smallest measurements are 38" x 24.5". The flush fin replacement window measures 36"x 24".
My questions are:
On the bottom of the existing window, I would have to cut the bottom lip so it flush with the stucco right?
You can see in the pic that the window is a little recessed by about 1 inch. I believe that won't be a problem since the window sits far into the window frame enough to screw it in.
Thanks for everybody's advice.
