I'm replacing some old heating duct with the latest flexible insulated duct. The attachments are 6" but the guy at the a home depot said you want to use 7" flex for easier installation. Is this correct? I plan to use mastic sealer and zip ties.
why? is something wrong with what is there?I'm replacing some old heating duct...
My main problem is the old insulation is falling off of the aluminum duct. When the heat is on in the living space above, it feels warm in the space below which I guess means leaks.why? is something wrong with what is there?
Gotcha (now that I see the pic).My main problem is the old insulation is falling off of the aluminum duct. When the heat is on in the living space above, it feels warm in the space below which I guess means leaks.
By the time you finish everything else you'll need to....do I need to reinsulate that distribution box in the photo?
