Despite the Cline thought process, I do agree that the removal of the mortar is the best way.. but not the only way.
Yes, you could level the flooring with floor leveling compound and float the wood over that.
Yes, you could use a foam/felt underlayment to over the difference, but it would not be covered under most warranties and that is what Mr Cline was most likely thinking. HOWEVER, in RARE cases that is option that can work. Though NOT the best option. Meaning you may have issues if you don't fall into a window of what is ok. So what would make the difference? They selection of the wood, A wider plank, or a 3 strip product would work better, Thicker in this case is also better, 9/16" or thicker. Also the mortar should be very even on the existing area. Why would you do this? Only if the other options are not possible for whatever reason.
