1 - 8 of 8 Posts
I thought it would be a good idea to install corbels under the counter to make the kitchen more aesthetically pleasing. However, I can not due to the angle of the counter vs the back of the cabinet is not 90 degrees. It's off by about 20 degrees.
The only two options I have is to shave off the 20 degree angle on the back of the corbel or to just return the corbels and not do it. It's an older house removing and replacing is not an option in order to make it 90. I appreciate any ideas you guys have! See attached photo.
Thanks!
retired framer
I can't imagine it looking right if it is not square with the wall below, as built.
I'd be setting at least a 4' level on top of that counter top to see if the whole top is not level, or just where it overhangs, or the short wall is out of plumb.
If it's a cheap particle board top it may have sagged and could be lifted.
Changing the style of corbel, or making your own would make it a whole lot easier to cut to fit.
Well, the countertop is showing it does not need the support because it is raising up on that side, rather than lowering. To me the top corbels are just something a child playing will bump their head in to or if it gets bar stools, they are a knee knocker. And if its just older people in the home, they seldom bend over that far to look for anything anyway. :)
Use shim to make up the difference then add small 1/4 round trim to cover the gap. But can you make your own? Or look for solid, thicker trim and cut to fit as suggested. Lumber yards may have it.
I have used bathtub corner guards that are adjustable.:smile: The middle part is in a groove. Maybe there are such adjustable corbels somewhere. Try searching.
Since it is just aesthetic mount it flush to wall and tight to corner. You won’t see gap under countertop
Sent from my iPad using Tapatalk
1 - 8 of 8 Posts
