Tapcon concrete screws work really well. You must use the correct size drill and a hammer drill. Using a regular drill or a well worn bit will cause problems, the Tapcon will pull out or snap. It will also snap if the hole is not deep enough so be sure to get a long enough bit and drill at least 1/8” deeper than the Tapcon. If you buy cheap masonry bits figure two or three holes per bit. A good bit will last much longer and you will know it is shot out because the Tapcons will get harder to drive. You want about 1" of bite into the wall so be sure to consider the depth of the nailing strip on your cabinet and a washer if you use one. I prefer the Tapcons with a hex head and usually use a drill/driver or 3/8 ratchet. These are pretty expensive if you purchase a small quantity so look for the bulk boxes in your big box store. Usually you will find them half to a quarter the cost in bulk.
Rege
