Hello,
I am building a full bathroom in my basement. I have completed the framing. Rough plumbing was completed when the house was built. I installed a peatrap for the shower. I am using a shower basin.
I have 3 other pvc pipes coming up from the basement floor. One waste for the toliet and two vents. I assume one vent is for the sink and the other for the shower.
I am confused on how to vent the sink. If I use 1 1/2" pvc for the sink waste, do I tie the sink waste into the vent pvc with a Sanitary tee? Can I tie both vent pipes together and run them up to the above bathroom vent pipe?
I am going to run the cooper as well. I see there is 3/4" pipe running out the main branch. Do I continue to run 3/4" pipe all the way to the sink, shower, and toliet -- then come down with 1/2" pipe to the shower, toliet, and sink? Also, does it matter where I add the shock absorbers at each fixture?
Is there anything else I should know? I appreciate your advice?
By the way, I live in the Chicagoland area just in case you needed to know.
