I recently moved into a new house and I am trying to figure out an inexpensive DIY charger solution. I am pretty handy but have very little electrical knowledge, i.e., I can change light switches, outlets, etc, but never done any major work. The new house is old but had a lot of upgrades done. The main panel (brand new) has a 2 pole, 20amp 240v breaker dedicated to the garage and the line runs to this old subpanel (photo attached). The line comes into the bottom of the subpanel and then out the top where it is distributed to various outlets in the garage, with the door opener plugged into one of them. It seems that they didn't run the ground from the main service, but this subpanel has a grounding rod running down beneath the floor of the garage (can see part of it in the photo, but none of the outlets in the garage are grounded (all 2 prong).
The subpanel is exactly where I want my charger to be. Can I use something like a 10 gauge power whip assembly to a 10-30 outlet? Can I trust the ground and set up a 14-50? (without running a ground from the main service). Would I run the wiring from "in front" of the subpanel? or take it after it goes through those old fuses?
I understand 240v 20amp wont charge that fast, but its better than a standard 120v outlet and my usual commute is very short and the car will charge overnight.
I know a lot of people will suggest I use an electrician but I just like doing things myself, and with COVID-19, I would prefer not to have anyone come to my house unnecessarily.
Thank you all in advance!
