Hi,
My daughter will be starting to learn to use the stairs soon and I want to make them safe. I'm kind of new to this home improvement stuff and I am not sure what solution would be best for this.
I have a stairway going to my upstairs with a handrail mounted on the wall. I would like to install a railing on the other side of that. Half of that side does not have a wall and is open the other half does have a wall. I only care about the open area which is about 5 steps. I looked at building a banister but I do not know if I need to go through the trouble of installing newel posts since it is such a small area.
Also since it is a tight area and difficult to move things into the house i would like the solution to be somewhat easy to remove. My first thought was the metal railings you use to find in houses in the 80's but i cannot seem to find those anymore.
The cieling also seems to be a problem when looking into things because it is only about 3' higher than the stair that meets the wall.
Any ideas???
(Picture is attached)
Thanks
Any ideas???
Thanks
