i will know some basic electral work and did some pot light, and new switchs before.
i will be installing a jetted bathtub (sorry cant post link newbi)
search Rectangular-Whirlpool-Reinforced-Tempered-Faucet-Freestanding/dp/B00T7W63NA
the motor has a plug at the end. i know it needs a dedicate line and gfci switch. i asked the salesman, he said it need requires a 110v but the manual saids 220v. (manual is not even the same modle0
the problem is i dont know what kind of wire i need to run it from the panel. lets said it needs 220v, can i just use those 3-way wire for power?? or do i use those stove wires??
btw i have a dedicate dishwashing machine that i dont use. can i use that???
The link does not provide any electrical details !
We need to know what the electrical requirements are ?
You say there are only 3 pins on the plug ?
We need to know if a neutral is required.
Then we can advise about where you can connect it ?
can you see any numbers on the plug ?
· Super Moderator
There is no such thing as 240 vo,t wire. You are confusing voltage with ampacity. Ampacity determines the wire size. How many amps does you tub need?
here is the information
-the 3pin said ft-3a
the motor infor are as follow:
-rating 110-120v 8.1 A 60 Hz p, 900w
3450 r/min PH 1 ip 55 cap 30uF/300 V
CODE D time CONT AMB 40ºC i.cl 105(A) sf 1.0
Thermally protected auto
is using a 14 gauge dedicate wire with face gfci alright
