I am installing a corner shower stall (neo-angle door), my base is very slightly off level, how should I fix this? Or can I ignore this?
Also, my base doesn't meet the walls (there is about 1/2 inch between the drywall that is already there and the base) can I put pieces of wood in there to frame the corner instead of moving the base and all the plumbing?
Can I drill screws into the vinyl sides that are supposed to be glued to the wall as well as use adhesive on the pieces of wood that I will put up?
Does the vinyl sides cover the inside of the base?
Thank you for your help!!
