We hired a local reputable company to install duraceramic tile in a floating fashion over our existing hardwood in our home. We chose, upon the advice of the dealer, the floating installation so as not to destroy the hardwood underneath because we wanted to have the ability to someday pull the tile up and keep the wood for resale value. Also, with the unstable substructure and movement of individual wood planks which are 2", the tile would be best to float (as described by the owner of the company who we went with). Well the other day we called them because of buckling in the tiles between two rooms and hair line cracking in the grout all over the 1600 sq ft area. When they came to fix we discovered that they glued down the tile to our hardwood throughout the install. Now, not only is our tile floor compromised and the grout issue will most likely get worse but our hardwood underneath is damaged and I don't even know if it is salvageable. What should I do with this? The owner knows he screwed up as we had a contract in writing for floating installation and said he would be in contact but I don't even know what I should ask for when we do talk.
Sorry for the long post.
