Newbie here... Thanks in advance
Two units, upstairs and downstairs, house built around 1990 and original equipment YORK vertical unit blower/furnace as closet units and two condensers outside. Added Emerson Sensi WiFi unit downstairs and connected C wire as instructed. No issues. Works wonderfully.
A week or two later, did the identical process upstairs but this time, the thermo never fired up and I smelled slight electrical burning from unit, specifically the transformer. The breaker never tripped. I put the old thermo back on (battery unit) and now nothing fires up as the unit (blower) is dead - no heat, no fan, and no AC. The transformer reeks of burnt electrical.
This is an older unit with no main motherboard (that I can see) and no fuse (please see pic). I found the replacement transformer online and have sent the (bad) thermostat back for a replacement. A few questions:
1) Could this be a short from the new thermo since it never fired up? (I tried to put the upstairs thermo on the downstairs faceplate to see if it would fire up but it wouldn't snap on. Something wasn't right as the pins would not line up on two identical units.
2) I found the new new transformer online. Is this something I can install myself? Will all the terminals be the same?
3) Can I add an inline 3-amp fuse to the C wire in case there's a short there?
I've done numerous repairs myself such as new capacitors and a new fan blade motor but nothing like this. Thanks for your help!
Mike
Mike
