We are sheetrocking the exterior walls of our laundry/utility room and I need to go around a hose bib penetrating straight out of the wall, as well as a PVC sewage pipe heading to the drain field. I can only see two ways to do this without breaking the pipes, which I'm not going to do.
- Leave the sheet as whole as possible, cutting a slot the diameter of the pipe from the closest edge to allow the sheet to be fed over the pipe. Pro: one less full length joint. Con: large patch needed to entire length of the slot
- Break the sheet at the pipe and cut a semicircle the radius of the pipe at the proper location so the sheets have a vertical seem in line with the pipe. Pro: probably easier to finish and have look good. Con: large vertical seam without the tapered edges.
Any input?
Need to post a picture so we can see what your seeing.
Retired Moderator
Any input?
None of the above--
Cut the hole in the sheet for the pipe---then cut out a V shaped wedge starting at the hole---this will give you the easiest to install sheet--and easy to block and tape.
I wish I had a picture for you---Mike---
