1 - 17 of 17 Posts
Retired Moderator
Why switch to pvc? It will use 2 sticks of copper --and give you a more solid install---
One of the plumbers from an area that allows different pipes will be along soon---
Here copper is code and I have no experience with the alternate piping--
Appears we should stick with copper, don't currently have the tools but will gettem.
Thanks!!
Retired Moderator
Torch--red tin of flux---plumbing solder and a good tubing cutter---those are the tools---
Plastic will be cheaper---I'm just not knowledgeable in those things--still might need the copper supplies for the conversion to plastic---Mike---
Thanks, its better to go better than cheaper, I'll pass it to my boss.
Located in Las Vegas NV.
Retired Moderator
Nevada probably allows for plastic pipe---let's see what a plumber says that knows about non copper piping---I live in a very restrictive part of the country---
mike does kane county follows Illinois plumbing code
PVC would not be used in a water pressure line.
Go with copper, Pex, or CPVC if codes allow.
Far better to go with all copper since that's what's already there
Retired Moderator
I work in DuPage and Cook county mainly---Most towns follow Chicago code--Copper only--type L---no Romex wiring--conduit only--
Kane county allows Romex but it's rarely used---
mike you are talking commercial ?
1 - 17 of 17 Posts
