1 - 8 of 8 Posts
Need to connect a Chint NC1 AC Contactor (NC1 - 1810) A float-switch in a water tank is 100m from the water pump. The float switch burns out after 6 months use. The float switch is connected to the L while the N is common directly to the pump motor and a power point. Have looked for a diagram on the net, but no luck. I'm not sure what goes where A1 - A2, L1 - L2 - L3 - 13 NO, T1 - T2 - T3 - 14 NO
Thanks
Did upload a diagram - hope it shows
Thanks JV, I can't get a float switch that is rated for the motor. Thats why I want to install the contactor, so the current runs through the contactor and not the float switch. If that makes any sense. Kind regards
Super Moderator
A1 is the line from the switch.
A2 will be the neutral wire.
L1 will be the hot wire that feeds the switch, and T1 will be the hot wire that hits the pump.
The coil is 120 volts correct?
I answered your question the first time. Lets be clear. The switch will open and close the contactor coil, not the motor.
1 - 8 of 8 Posts
